I am trying to translate WooCommerce products on my site hidden link using WPML. I have previously created two support tickets for similar issues, which were resolved. However, the solutions from those tickets are not working this time.
Some products are stuck on 'loading' status, and the translation doesn't get updated.
Languages: English (English )Spanish (Español )Italian (Italiano )
It seems that there is some server restriction as the website appears blocked when you try to translate.
Do you give me permission to download a copy and check if the issue is reproduced on local server? That way we will know if it is server related issue.
I did the instructions but the migration did not happen.
The form has other field:
Where do you want to migrate your site?
"Cloudways Flexible" or "Cloudways Autonomous"
And other yes/no questions:
HTTP Auth enabled?
Any root directories you want to migrate?
Migrate additional database tables?
Is this site password-protected?
And also there was no field for database username and password.
I tried bot "Flexible" and "Autonomous" version with all yes/no questions set as "no", but I got this error:
Incorrect folder selected. Your destination site ***destination site*** is not being served from the selected folder.
Hi there!
As there was problems with the cloudways migration, I have downloaded copy of your site. Locally everything works fine. It seems a server related issue. Please contact your sever to see if there is any restrictions.
I have made a video where I show you that everything works fine locally: hidden link
I tried translating again on the production site and the new product translation works. Something changed, but it still has issues.
Can you try translating the product with this SKU?
FLKF001
Originally, the content for both languages was the same. But then we checnged the attributes on the original language, but the translated language did not change.
I tried the usual troubleshooting page tools, changing content on the original and revert the change, but it's not working.
The topic ‘[Closed] Woo Product translation issues’ is closed to new replies.
