If you're experiencing issues where some WooCommerce checkout strings, such as 'Населённый пункт' and 'Saadetis', are not using the translations set in WPML → String Translation in both Estonian and Russian languages, despite having disabled automatic updates and cleared caches.
We recommend exporting the .pot file with the updated strings from a test site where the issue is already resolved. You can do this via WPML → String Translation → Import/Export → Export strings. Then, import this .pot file into your live site using the same WPML → String Translation → Import/Export path. This process is safe to perform on a production site and should not affect your existing content or database structure. Additionally, this fix should remain effective after future WPML or WooCommerce updates, although you may need to re-scan for new strings or re-export/re-import the .pot file if updates introduce changes.
Please note that this solution might be irrelevant if it's outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
This topic contains 22 replies, has 0 voices.
Last updated by 1 month, 1 week ago.
Assisted by: Dražen.
