Last updated by Dražen 1 year, 7 months ago.
Assisted by: Dražen.
December 14, 2023 at 4:18 pm #15066515
Verbal
Working on fixing a plugin compatibility issue with Woocommerce Multilingual.
In wp-admin, a product list populated via admin-ajax.php?action=product_ajax&security=XXXXXXX&search=NAME_OF_THE_PRODUCT needs to get all products returned by the search query, regardless of their language.
WPML filters the output and only returns products in the current language. How can I tell it not to? Is there a parameter or hook that could be used?
December 18, 2023 at 8:10 am #15080949
Dražen
thanks for contacting us.
You can add a lang parameter at the end of your URL, for example like this:
wp-admin/edit.php?post_type=product&lang=all
Let me know how it goes and if this helps.
Drazen
December 18, 2023 at 12:55 pm #15084333
Verbal
The product list / ajax call is not made from wp-admin/edit.php?post_type=product, but from a plugin that calls admin-ajax.php?action=product_ajax&security=XXXXXXX&search=NAME_OF_THE_PRODUCT
Is there a way to not filter the ajax call?
December 18, 2023 at 2:03 pm #15084865
Dražen
You can try using the wpml_current_language hook as explained in our docs to filter for each language:
- https://wpml.org/wpml-hook/wpml_current_language/
- https://wpml.org/documentation/support/debugging-theme-compatibility/#issue-custom-non-standard-wordpress-ajax-requests-always-return-the-default-language-content
Or if you are using WP Query to get products you can then use suppress filters:
- https://wpml.org/documentation/support/debugging-theme-compatibility/#issue-wp_queryargs-or-get_postsargs-doesnt-filter-out-correct-posts-ids-for-the-current-language
Let me know if that helps.
Drazen
