Home›Support›English Support›[Resolved] Woocommerce gutenberg checkout product block not getting translated
Problem: The Gutenberg checkout block integrated with WooCommerce is not getting translated on the frontend. Solution: If you're experiencing this issue, we recommend enabling the 'Automatically load the theme's .mo file using 'load_textdomain'' option in WPML-> Theme and Plugins Localization. This adjustment resolved the problem for the client.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum for further assistance.
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Preferably to a test site where the problem has been replicated.
I enabled the "Automatically load the theme's .mo file using 'load_textdomain'" option in WPML-> Theme and Plugins Localization, which fixed the issue.
Thank you Osama, I'll be sure to try that if I face similar problems again.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
