If you're experiencing issues where product quantities are not updating across different language versions in your WooCommerce store after a sale, this could be due to the WooCommerce Multilingual plugin not being active.
We recommend activating the WooCommerce Multilingual plugin to ensure that stock statuses are synchronized across all languages. Here's how you can resolve the issue:
1. Activate the WooCommerce Multilingual plugin. If it's not installed, navigate to Plugins > Add New > Commercial and install it from there.
2. Once activated, retranslate the affected product.
3. Go to WooCommerce > WooCommerce Multilingual > Status tab.
4. Scroll down to the "Troubleshooting" section and select the option as shown in this screenshot: https://prnt.sc/r8qJw53f8lSO. Then, click on the Start button to synchronize the stock status across languages.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket at WPML support forum.
Last updated by 1 year, 7 months ago.
