You are using WPForms and WPML integration, and it is translating all the Smart Tags like {all_fields}, which stops them from working properly. The Smart Tags are being translated, resulting in {all_fields} being shown as {alle_Felder}.
We recommend adding the following code to your functions.php file to prevent Smart Tags from being translated:
// WPML Workaround for compsupp-7788
add_filter( 'wpml_tm_job_field_is_translatable', 'compsupp_skip_wpforms_smart_tags', 10, 2 );
function compsupp_skip_wpforms_smart_tags( $is_translatable, $job_translate ) {
$data = $job_translate['field_data'];
if ( 'base64' === $job_translate['field_format'] ) {
$data = base64_decode( $data );
// Check if data exists and starts with '{'
if (isset($data) && strpos($data, '{') === 0) {
return false;
return true;
This solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If this does not resolve your issue, please open a new support ticket.
Last updated by Dražen 1 year, 2 months ago.
Assisted by: Dražen.
January 8, 2025 at 11:35 am #16573037
pascalS-9
I am using the WPForms and WPML integration, and it is translating all the Smart Tags, which stops them from working. I am trying to prevent them from being translated. There are strings like {all_fields} and all hidden values. Link to a page where the issue can be seen: hidden link
How can we stop Smart Tags from being translated?
January 8, 2025 at 12:06 pm #16573138
Dražen
I have added the Pro version of the plugin:
- hidden link
Please try to reproduce it and share a step-by-step guide so I can try it also.
Drazen
January 8, 2025 at 12:44 pm #16573367
pascalS-9
Done, I have added 3 of them and translated the form and, they are being translated but in this case, there is an "es" added to the beginning which might be related to the translating engine.
You can check the site or screenshots below
January 8, 2025 at 1:16 pm #16573575
Dražen
thanks, I have escalated this issue to our compatibility team for a permanent fix, in the meantime as a workaround you manually edit and adjust the translation for these tags, and make them correct.
Drazen
January 14, 2025 at 7:43 am #16591433
Dražen
can you please try next workaround and re-translate the form:
Workaround
Add the following code in your functions.php file
      return false;
  return true;
Drazen
