Last updated by Shekhar Bhandari 1 year ago.
February 17, 2025 at 8:27 am #16712036
easy-plus-software-wllE
I am trying to add multiple different products to the cart using WPML. When I add a single product, it works as expected. However, when I add multiple different products, the second product initially appears in the cart but disappears after a page refresh. If I add the same product twice, it remains in the cart. Disabling WPML resolves the issue, confirming it as the cause. Link to a page where the issue can be seen: hidden link
The second product disappears from the cart after a page refresh when multiple different products are added. The issue does not occur when the same product is added twice.
Why does the second product disappear from the cart after a page refresh when using WPML?
How can I resolve the issue of products disappearing from the cart without disabling WPML?
February 20, 2025 at 12:28 pm #16729508
as you asked in chat I send the database and wp-content file. can you please tell me the status?
February 20, 2025 at 2:40 pm #16730349
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
I haven't received the wp-content and database backup till yet, can you provide me the links to download it so I can test it further?
Look forward to your reply.
February 24, 2025 at 10:20 am #16740137
Shekhar Bhandari
Hello there,
Can you please go to comment the below code or remove it for some moment and check if it helps? .../wp-content/themes/gostore/framework/woo_functions.php
function gostore_update_tini_wishlist() {
	die(gostore_tini_wishlist());
add_action('wp_ajax_gostore_update_tini_wishlist', 'gostore_update_tini_wishlist');
add_action('wp_ajax_nopriv_gostore_update_tini_wishlist', 'gostore_update_tini_wishlist');
February 25, 2025 at 12:50 pm #16745759
I am still facing the problem. I comment the code but still same issue.
February 25, 2025 at 4:46 pm #16747165
Shekhar Bhandari
Hello there,
I am sorry for the trouble, I can still see the issue.
To troubleshoot the issue further, I created a public test site here: hidden link
You can visit shop page here: hidden link
I have made a small change on the sandbox site: .../wp-content/themes/gostore/framework/woo_functions.php and modified the following code
add_filter( 'wcml_multi_currency_ajax_actions', 'gostore_wcml_multi_currency_ajax_actions_filter' );
if( !function_exists('gostore_wcml_multi_currency_ajax_actions_filter') ){
	function gostore_wcml_multi_currency_ajax_actions_filter( $actions ){
		$actions[] = 'remove_from_wishlist';
		$actions[] = 'gostore_ajax_search';
		$actions[] = 'gostore_load_quickshop_content';
		$actions[] = 'gostore_update_cart_quantity';
		$actions[] = 'gostore_load_product_added_to_cart';
		$actions[] = 'ts_get_product_content_in_category_tab';
		$actions[] = 'ts_elementor_lazy_load';
		$actions[] = 'gostore_tiny_cart_filter';
		return $actions;
Can you check if this helps, for me it looks like it's fixed.
February 25, 2025 at 7:14 pm #16747595
I added to code to the live website but still same problem.
February 27, 2025 at 2:42 am #16753819
Shekhar Bhandari
Hello there,
Can you check on the test website if you can reproduce the problem.
Further, I suggest you to clear the cache on your live site to check the issue once.
March 1, 2025 at 12:10 am #16763049
please check now. the test website has the same problem
March 3, 2025 at 4:31 am #16766708
Shekhar Bhandari
Hello there,
I have escalated the issue to our compatibility team for further debugging, I will update you as soon as I will receive any feedback from them.
The topic ‘[Closed] WPML Causes Issues with Adding Multiple Products to Cart’ is closed to new replies.
