Hello! 2 problems with the plugin:
1. Can't edit in Elementor and export files, the problem is in your plugin, as it allows to edit site pages only in safe mode. After deactivating the plugin, everything works. Please fix it.
2. Your plugin blocks alt tags of images on the page and gives an error. Also need to be fixed.
As the chat was idle for a long time, I had to convert the chat to a ticket. We can continue the conversation through this ticket.
- For the Safe Mode issue: This error typically arises when the site doesn't have sufficient resources like Memory Limit or TimeLimit. Could you please provide the WPML Debug information in your next response so that I can get a better overview of the site and system? You can find instructions on how to obtain the Debug Info at this link: https://wpml.org/faq/provide-debug-information-faster-support/
Once you have the information, please insert it into the Debug Information box that will appear when you respond.
- WPML blocks alt tags of images on the page and gives an error: The error you've pointed out isn't entirely clear. Could you please provide additional details or context to help understand it more effectively? If you could share the steps to reproduce the problem, along with any error messages you've come across, it would greatly help in understanding the issue.
After receiving the requested information, I'll review it and advise you on the next steps. Looking forward to your response.
Prosenjit
The topic ‘[Closed] WPML causing Elementor Safe mode issue and blocking alt tags of images’ is closed to new replies.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
