Last updated by Sumit 1 year, 11 months ago.
August 14, 2023 at 11:21 am #14196901
vishalG
We explained our situation in this thread (https://wpml.org/forums/topic/wpml-content-copy-is-not-working-with-acf-block/) but as it was signed resolved without us commenting further on it, I am opening a new issue.
The solution that was offered to us to choose "Copy" or "Copy once" on the fields we had a problem with. The reason we cant use this solution is that those fields are not showing up on the settings section, so we cant choose those options. What could be the reason of those fields not showing up on the Custom Fields Translation settings?
August 14, 2023 at 3:56 pm #14198655
Sumit
Thank you for contacting the support forum.
Before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process.
Sorry about your experience. Our automated process closes the ticket if we receive no reply within a week or two. Please add a reply in a couple of days even with a simple message that you need more time to keep the ticket open.
About your issue, you are not seeing the option because you may have selected the same fields across the languages. Please see https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/#using-the-acf-multilingual-setup
If you have selected the mode same fields across the language then you don't need to change any settings.
However, we are not sure what exactly the issue is. From your last message, I see our team said
I reviewed the video but it seems that it was not entirely completed. The video was 29 seconds long and ended during the saving process, which is why, I couldn't be able to identify which fields do not appear in the backend.
Also, the video is not there on the provided link. I would suggest describing the problem in a complete video so we can understand the issue.
Also, please records the screen of your custom field to see the exact mode you are using.
The topic ‘[Closed] WPML Content Copy is not working with ACF Block’ is closed to new replies.
