Last updated by vigoZ 3 days, 15 hours ago.
Assisted by: Dražen.
February 11, 2025 at 12:50 pm | |
vigoZ |
February 11, 2025 at 1:11 pm | |
February 11, 2025 at 1:13 pm #16691710 | |
Dražen Supporter
Languages: English (English ) Timezone: Europe/Zagreb (GMT+01:00) |
Hello, as notified I have created a ticket, so let's continue here. 1) Create a staging site and confirm issue still happens when usingthe Porto default parent theme, and only WPML plugins and Wocommerce, all others disabled. 2) Update WPML plugins to the latest versions from Plugins > Add new > Commercial tab and click Check for updates. 3) If the issue still happens please share admin and FTP access to staging site so I can check and confirm the issue. Regards, |
February 11, 2025 at 1:31 pm #16691905 | |
vigoZ |
Update. add_filter('woocommerce_ajax_variation_threshold', function() { return 500; }); or add_filter('woocommerce_ajax_variation_threshold', 'custom_wc_ajax_variation_threshold', 10, 2); was conflicting with WPML String Translator. After trying many combinations, and deleting the script, the product shows up, but yes, the variation doesn't work as it should. (not working product variation filtration, when selecting any attribute, all others shown available). Video: hidden link |
February 11, 2025 at 1:34 pm #16691924 | |
vigoZ |
Can I just drop the credentials here in chat? I do not see any "Add credentials" |
February 11, 2025 at 1:54 pm #16692014 | |
Dražen Supporter
Hello, as I understand original issue is solved and your custom code was the culprit for that problem. As for 2nd part of the issue, we might need to understand better the issue and open a new ticket since we limit 1 issue per ticket to keep things and conversations clear. 1) Does the issue happen on your default language or translated product? 2) Does the issue happen when WPML plugins are disabled? 3) Does the issue happen when using the WP default theme and only WPML plugins and Wocommerce enabled? Regards, |
February 11, 2025 at 3:04 pm #16692479 | |
vigoZ |
1) In the default language, this product is still not translated. Saved you 2 hours of debugging 🙂 |
February 12, 2025 at 7:04 am #16694210 | |
Dražen Supporter
Hello, thanks for the detailed debugging and for getting back to us. So, let's get back to the original issue with the product not being rendered, and if you have any other issue please opew new ticket for it. As I understood from your last reply product layout shows up fine in such cases: As it seems the issue is with your child theme/custom code, note that we can not debug or support custom code or issues with custom code as per our policy. For such cases, you can hire WPML Contractor: https://wpml.org/contractors/ Let me know if I maybe understood something wrong here and we can still help out. Regards, |
February 12, 2025 at 7:41 am #16694320 | |
vigoZ |
I could agree, but the fact that the child theme is not working with WPML String translator I can also point to your side, not only to the Porto theme. So you also must check from your side, why WPML String translator is conflicting with the Porto child theme. I am also in contact with Porto developers and of course, they are saying "Please contact with WPML, because after the installation of WPML the issue appears." |
February 12, 2025 at 9:27 am #16694898 | |
Dražen Supporter
Hello, sure, if the Porto child theme is the default one, and not with some added custom code. That is what I have assumed from the reply, that the child theme has some custom addition there and it works fine with the default parent theme where there is none. If you wish, sure I can check further on the staging site or duplicator, but note that I will create a new child theme (use latest parent theme) and check if the issue happens if your child theme contains some custom code/changes. Regards, |
February 17, 2025 at 7:29 am #16711799 | |
vigoZ |
Issue not solved. |
