You are experiencing an issue where email notifications are not being sent when using 'Bulk Actions' on the order page due to a conflict between the WPML string plugin and your order plugin. This conflict arises because both plugins use the
woocommerce_order_status_changed
hook, and the WPML-related code switches the locale to English, interrupting the email sending process.
We recommend adding the following code snippet to your theme's functions.php file after ensuring you have a full backup:
add_action('woocommerce_order_status_changed', function () {<br />    $tag = 'woocommerce_order_status_changed';<br />    $prio = 10;<br /><br />    $callbacks = $GLOBALS['wp_filter'][$tag]->callbacks[$prio] ?? [];<br />    foreach ($callbacks as $cb) {<br />        $f = $cb['function'];<br />        if (is_array($f) && is_object($f[0]) && $f[1] === 'comments_language') {<br />            remove_action($tag, $f, $prio);<br />        }<br />    }<br />}, 0);
This code removes the WCML action that changes the locale when the other plugin calls
restore_previous_locale()
. With this adjustment, the process should complete correctly, and your emails will be sent as expected.
Please note that this solution might become irrelevant due to updates or may not apply to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
This topic contains 18 replies, has 0 voices.
Last updated by walter-arielM 7 months, 1 week ago.
Assisted by: Marcel.
September 23, 2025 at 3:42 pm #17426267
walter-arielM
Ok. Thanks.
Please, let me know.
September 24, 2025 at 1:25 pm #17429287
Marcel
so your order plugin is adding custom logic related to WPML. The issue you’re seeing is caused by that custom logic hooks into woocommerce_order_status_changed. This same hook is also used by our WooCommerce Multilingual (WCML) plugin.
The problematic code is located here:
/wp-content/plugins/bp-custom-order-status-for-woocommerce/src/Email.php
Everything works correctly until the call to restore_previous_locale(). That call triggers a chain in WooCommerce Multilingual (WCML), specifically in:
\WCML_Emails::comments_language
/wp-content/plugins/woocommerce-multilingual/inc/class-wcml-emails.php
This method sets the locale to English because of a fallback condition. Once the locale is switched to English, the process is interrupted and no further emails are sent.
There’s one catch: this issue only appears if your WordPress admin top-bar language is set to Spanish. The reason is most likely that Post Status is a Custom Post Type (CPT). Since you’re using “Display as translated” mode without providing actual translations, the defaults remain in Spanish, which triggers the mismatch.
Workaround
As a workaround, you can add the following code snippet to your theme’s functions.php after a full backup:
    $prio = 10;
}, 0);
This removes the WCML action that changes the locale when the other plugin calls restore_previous_locale(). With this in place, the process should complete correctly and your emails will be sent as expected.
Marcel
September 25, 2025 at 3:35 pm #17433359
walter-arielM
Thanks. I will try the code you sent me.
Please, keep open this ticket a few days more.
Walter.
September 25, 2025 at 3:39 pm #17433378
Marcel
Sure!
Best Regards,
Marcel
September 29, 2025 at 6:34 am #17439519
walter-arielM
Hello there,
It seems that the issue is fixed.
Thank you very much for your support.
Walter.
