This topic contains 17 replies, has 1 voice.
Last updated by Christopher Amirian 1 month, 3 weeks ago.
March 18, 2026 at 5:12 pm #17908928
sfatL
I tried extensively, but the snippet did not help at all.
March 18, 2026 at 5:13 pm #17908929
sfatL
Is this WPML problem, Yoast problem, or combination of both? Perhaps we should try to migrate to RankMath and check if the problem persists then?
March 19, 2026 at 9:13 am #17910168
Christopher Amirian
WPML Supporter since 07/2020
It is very hard to know what the problem is as there is no concrete way of replicate the problem.
Please check the video below to see how I tested according to your information:
Also, now that the script has nothing to do, it should be obvious that the previous point that you mentioned is not the cause of the issue.
As mentioned in the video, if there is a way to replicate the problem I will be more than happy to report this asap.
