Last updated by Bobby 1 year, 1 month ago.
Assisted by: Bobby.
March 16, 2025 at 10:57 pm #16822482
aleksandrK-22
I am trying to translate endpoints on my WordPress site using WPML. The site I need help with is hidden link.
Your product permalink base is not translated to.
How can I translate endpoints using WPML? Can I leave all endpoints in English? Why do endpoints to translations of endpoints appear in String Translation?
March 18, 2025 at 10:54 pm #16832811
Bobby
WPML Supporter since 04/2015
What are your results when clicking on the "Translate URLs" button?
Please share a screenshot with me of the results.
March 20, 2025 at 2:45 pm #16840642
aleksandrK-22
I have already added screenshots. Where can I find information on how to translate WooCommerce? For example, if I translate the slug shop, the product labels are not displayed correctly. I decided to leave everything in English. Is it possible to do this?
March 20, 2025 at 7:51 pm #16841785
Bobby
Thank you,
I recommend reviewing this documentation on how to create a multilingual WC store.
https://wpml.org/tutorials/2022/06/creating-a-multilingual-woocommerce-site-with-wpml/
You can leave the URLs not translated, if that works for you it will not cause issues with WCML.
When you translate the shop URL I also recommend going to Permalinks and making sure the WC shop base URLs are set ok, then going to WPML->String Translation and reviewing the URL there as well in case a trnaslation is mixed.
I'd be happy to take a further look if you would like to make sure it's all set up as expected. You technically should be able to translate those with no problem.
The topic ‘[Closed] Your product permalink base is not translated to’ is closed to new replies.
