The client's website, which was translated from French to English, has some fields incorrectly registered as English translated to French, instead of the correct way around.
We recommend checking the language in which the taxonomies were added, as they might have been created in the incorrect language by mistake. To correct this, you can edit the taxonomy and change its language.
Additionally, you can connect it to the correct translations. For detailed instructions, please follow our guide on Translating Post Categories and Custom Taxonomies.
If this solution does not apply to your case, or if it seems outdated, we encourage you to open a new support ticket. We also highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins.
Last updated by 1 year, 9 months ago.
Assisted by: Waqas Bin Hasan.
