Last updated by Osama Mersal 1 year, 10 months ago.
Assisted by: Osama Mersal.
August 28, 2023 at 4:44 pm #14302547
nikiforosB
Hi, I have translated the page, the listing, the posts, the taxonomies and almost everything. I have also selected the translated listing in the listing grid but it returns no posts. The Jet smart filter does recognize that there is a post translated but is not shown.
August 29, 2023 at 6:27 am #14304059
Osama Mersal
WPML Supporter since 02/2020
Please let me know how to reproduce the issue.
Also, I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Your next answer will be private, which means only you and I can access it.
Osama
August 29, 2023 at 9:13 am #14305643
Osama Mersal
Thanks for the access details. I checked the issue and found that the query in the Elementor posts widget sorts by meta value. When changing that to the post's title or date, the listings work correctly. (Kindly check this hidden link)
Would you please check if the trips and destinations pages work correctly?
August 29, 2023 at 12:48 pm #14307303
nikiforosB
Ok, thanks, I realized that this field was set as not translatable so the data was not transferred in the Greek translation. Thank you for your help, have a great day.
