If you're experiencing discrepancies in stock levels between different language versions of the same product, such as seeing different stock counts in English and Greek for the same item.
First, ensure that you have installed the 'WooCommerce Multilingual & Multi-Currency' addon. You can do this by navigating to Plugins > Add new > Commercial in your WordPress dashboard and installing the addon.
Once the plugin is active, it should automatically synchronize stock and prices across different languages. If the stock levels still do not match, try updating the stock on the original product, as this should correct the stock levels in all languages.
Additionally, check your settings under WPML > Settings > Custom Field Translation to ensure that stock synchronization is configured correctly. Also, visit WooCommerce > WooCommerce Multilingual & Multi-Currency > Support to verify there are no configuration issues.
For more detailed guidance on translating WooCommerce products with WPML, please read our documentation: https://wpml.org/documentation/related-projects/woocommerce-multilingual/
If these steps do not resolve your issue, or if the solution seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If needed, please open a new support ticket at WPML support forum for further assistance.
This topic is split from https://wpml.org/forums/topic/bar2-product-options/
Last updated by 1 year, 2 months ago.
