I am trying to: Show the translation of this ACF fields here hidden link in Greek. as you can see all custom fields except the section "Στοιχεία ακινήτου" (Property Details) is translated. only in this section is not translated.
Please go to WPML -> Settings -> Post Types and check to make sure Field Groups are set as Not Translatable.
Then, go to your ACF field group for this content and expand the fields. What are your settings for translation for these fields? Are they set as Translate, Copy, Copy Once, or don't translate? In order to translate them, they should be set to Copy Once or Translate. If not, you will not see them available for translation in the translation editor.
Thank you,
Bobby
The topic ‘[Closed] Problem with ACF and Jet Engine’ is closed to new replies.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
