Last updated by Andreas W. 2 weeks ago.
September 17, 2025 at 5:57 pm #17410969
Vincent Dagenais
I'm creating a translatable product using WooCommerce and programmatically creating products. I need to set custom taxonomy to the original product and translated product and link them together.
I need help attaching custom taxonomies to products.
How do I attach custom taxonomies to both original and translated products?
How can I link custom taxonomies between original and translated products?
September 18, 2025 at 6:32 am #17411647
Hello Vincent,
Thanks for your question. To attach custom taxonomies to both original and translated products, you’ll want to:
Assign the taxonomy term to the original product using wp_set_object_terms().
Use WPML’s wpml_object_id filter to retrieve the translated term ID for each language.
Assign the translated term to the translated product using the same function.
Example:
$translated_term_id = apply_filters( 'wpml_object_id', $original_term_id, 'your_custom_taxonomy', false, $target_lang );
wp_set_object_terms( $translated_product_id, array( $translated_term_id ), 'your_custom_taxonomy' );
The hook:
https://wpml.org/wpml-hook/wpml_object_id/
Also, make sure your custom taxonomy is marked as “Translatable” in WPML settings and translated at WPML > Taxonomy Translation.
The topic ‘[Closed] i’m creating a translatable product and need help attach custom taxonomies’ is closed to new replies.
