Last updated by Long Nguyen 11 months, 3 weeks ago.
Assisted by: Long Nguyen.
July 19, 2024 at 1:09 pm #15978554
ioannisP-26
I am experiencing a problem with translation and display of texts after uninstalling and reinstalling WPML on my site hidden link.
Video: hidden link
<b>Symptoms: </b>
Problem with translation and display of texts after uninstalling and reinstalling WPML.
<b>Questions: </b>
How can I fix the translation and display issues after reinstalling WPML?
July 22, 2024 at 2:48 am #15984357
Long Nguyen
WPML Supporter since 02/2022
Thank you for contacting WPML support, I’m happy to help you with this issue.
I understand the issue here is the new content of the page isn't available in the Advanced Translation Editor for translation. Based on the debug info, I see you are using the Classic Editor plugin so I suggest you follow the workaround in the ticket below to use the Block editor to make changes to the original page and see if it helps.
https://wpml.org/forums/topic/cannot-translate-posts-in-wordpress-editor/#post-15984210
July 22, 2024 at 1:46 pm #15987229
ioannisP-26
Hi!
The link is not available for me.
"This is a private ticket
Only the author can view this ticket"
July 23, 2024 at 1:19 am #15989777
Long Nguyen
Here are some steps to fix the issue:
1. Deactivate the plugin Classic Editor.
2. Edit the post with Block editor.
3. Hover over the content and click on "Convert to blocks".
4. Make a small change to the post content > Save.
5. Update the translation in ATE.
Edit Post “Unlocking the Power of Individualized Online Tutoring” ‹ Llama Learning — WordPress 2024-07-22 08-33-05.png
The topic ‘[Closed] Problem with translation and display of texts after uninstalling and reinstalling wpml.’ is closed to new replies.
