The client is experiencing incorrect product quantities displayed next to the WooCommerce product filter in languages other than the default language on their website.
To address this issue, follow these steps:
- Navigate to Products -> Attributes.
- Click "Configure terms" to access the "Kompatybilność" attribute terms.
- Click on the number of products next to the problematic term to view all products in this term.
- Select all products.
- From the "Bulk Actions" dropdown menu, choose edit.
- Change the status to "Publish" and update them.
If these steps do not resolve the issue or if the solution seems outdated or irrelevant to your specific case, we recommend opening a new support ticket. We also highly recommend checking related known issues at WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
This topic contains 20 replies, has 2 voices.
Last updated by przemyslawD-3 6 months ago.
Assisted by: Osama Mersal.
August 29, 2024 at 11:50 am #16119743 | |
przemyslawD-3 |
August 29, 2024 at 2:40 pm #16120662 | |
przemyslawD-3 |
I did all the steps step by step, unfortunately it did not solve the problem 🙁 |
September 1, 2024 at 9:25 am #16128611 | |
Osama Mersal Supporter
Languages: English (English ) Arabic (العربية ) Timezone: Africa/Cairo (GMT+02:00) |
Hi, Thanks for contacting WPML forums support. I'll be glad to help you today. First of all, sorry for the late reply; it was due to a higher workload. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Your answer will be private, meaning only you and I can access it. ❌ Please backup your database and website ❌ ✙ I need your permission to deactivate and reactivate the plugins and themes and change site configurations. This is also why the backup is critical. ✙ I also need your permission to take a local copy of your site to debug the issue without affecting your live site. Best regards, |
September 2, 2024 at 11:20 am #16131196 | |
Hi, Thanks for the access details. I Synchronized the attribute from the WooCommerce Multilingual-> Attributes tab. This fixed the issue for the English language. Kindly check this hidden link">page. Best regards, |
September 2, 2024 at 12:19 pm #16131541 | |
przemyslawD-3 |
Ok, I don't know why, but I tried this before and it didn't work. I don't know what exactly you did, but etraz one of the translations is missing (Switzerland) and I see a critical error when editing the translation 🙁 |
September 2, 2024 at 12:29 pm #16131584 | |
Hi, I checked the site and re-added the Switzerland language. Please check if it works correctly. Best regards, |
September 2, 2024 at 12:34 pm #16131600 | |
przemyslawD-3 |
Not really. I see the language, but the translation on the page is wrong (part is Polish, part is English). Everything should be in German (except the currency). |
September 2, 2024 at 12:43 pm #16131665 | |
Hi, Please check this hidden link">product and let me know which strings have not been translated. Best regards, |
September 2, 2024 at 12:51 pm #16131691 | |
przemyslawD-3 |
On the yellow on screen & cookie banner. |
September 2, 2024 at 1:04 pm #16131804 | |
Hi, I translated some of these strings via WPML-> String Translation. Please let me know how the "The product has no reviews" string and the cookie banner are added to the default language to check how they can translated. Best regards, |
September 2, 2024 at 1:17 pm #16131851 | |
przemyslawD-3 |
Cookie banner: CookieYes | GDPR Cookie Consent plugin But there is more thing withaut translation (checkout form, etc.). Maybe it will be easier to restore database and start once again? |
September 2, 2024 at 1:22 pm #16131884 | |
Hi, If you have a recent backup, you can do so. Please take a backup of the current database first. Best regards, |
September 2, 2024 at 1:31 pm #16131971 | |
przemyslawD-3 |
Ok, I suggested restoring the database too soon. In the meantime, orders came to the store, and a colleague changed some things, and restoring the database from 6 a.m. is not the best idea if it is not necessary. It will be easier to translate the forms. I will take care of it myself. However, the original problem is still not solved - on versions other than Polish and English it still shows incorrect quantities of products. |
September 2, 2024 at 1:54 pm #16132122 | |
Hi, I updated the translations, and the filter appeared to be correct. Please check the hidden link">German page. Best regards, |
September 3, 2024 at 10:46 am #16135040 | |
przemyslawD-3 |
Two things: 1) Can you write exactly what (or how) you refreshed the attributes? It's strange that I've done this many times and it doesn't work. 2) I still have a problem with the translation to Switzerland. And even with another translation - I just can't find the basic strings. For example this one below - it's translated to every language (except Swiss version), but I can't find it in the string translation. I tried to scan plugins, theme, find it in the admin translation panel and there's nothing. This string shows up after adding a product to the cart. Edit: if I tried to scan woocommerce .mo it's stopoing at keep bufforing at -134. |
