- 12:00 – 16:00 10:00 – 14:00 10:00 – 14:00 9:00 – 13:00 9:00 – 13:00 -
- 17:00 – 21:00 15:00 – 19:00 15:00 – 19:00 14:00 – 18:00 14:00 – 18:00 -
Supporter timezone: Europe/Bucharest (GMT+03:00)
Last updated by Mihai Apetrei 3 hours, 2 minutes ago.
Assisted by: Mihai Apetrei.
October 1, 2024 at 10:46 am #16239754
jorisR-3
I am trying to translate the 'read more' text on this website hidden link and the strings are not showing up anywhere. I have already tried all the documentation.
Some Uncode parts are not translated.
How can I translate the 'read more' text on my website?
Why are the strings not showing up in WPML?
Page URL with issue: hidden link
October 1, 2024 at 12:46 pm #16240477
Mihai Apetrei
Hi there.
I am not sure which exact steps you have followed but the proper way to translate strings depends a lot on how they have been implemented inside the theme/plugin.
Please try both methods that I will mentione below and see if any of them resolves the issue.
Method 1:
Go to WPML > String Translation and at the bottom of the page you will find a checkbox called "Look for strings while pages are rendered". You can enable (check) that and then go to the front end to a page where you have that string showing up and then go back to WPML > String Translation and search for that string and see if it now shows up.
Method 2: If you can't find them inside the WPML > String Translation, they might be added as admin text strings.
This should be the normal process to find and translate admin text strings:
https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/#translate-admin-and-settings-strings
Please let us know how that goes.
Related documentation:
Kind regards,
Mihai Apetrei
