I will copy it as a new website in my localhost and be testing to define what is the problem.
However, I got a problem with the Layout on ES. If I create a new section as and type name for this, the section will be moved in English without reason or error.
If you have time or would like to help us, you can catch it. I think you have more experience than me.
I have deactived the plugin wordfence and you can login pls.
Debug: I have turn on the debug mode via wp-config.php
I changed the config for avada layout to " do not translate ". I think that is unnecessary to have a different layouts for our website. I thought , we just need to translate the sections and the design will be changed automatic on frontend.
However, I saw an error of Javascript "layouts.js" in Avada THeme by ajax loading that when I click loadmore or search any information the avada them stops working. I need to copy the website to localhost and try to fix this problem.
I think it is an error or conflict in wpml , because I created new website with avada theme that everything is working well without error. But for the website the ajax of avada js is not working when I turn off WPML Plugin.
When I try to log in to the site to further troubleshoot the issue it no longer works.
Can you please re-send the working site access details after backing up the site completely?
PS: I have enabled the private reply for you to share the details.
Or if it suits you, you can also send me a copy of the site so that I can troubleshoot the issue further on a local copy of the site as explained in the link next:
