Last updated by Bobby 5 days, 16 hours ago.
Assisted by: Bobby.
August 29, 2025 at 7:10 am #17356860
alenL
Hi Bobby,
Suggested steps did the trick. That part is now all right.
Can you check about this page also: hidden link
Filter labels aren't translated.
August 29, 2025 at 7:11 am #17356862
Bobby
WPML Supporter since 04/2015
Regarding the filters, how are these filters added?
Are they native to Divi?
This will help me better understand how to best translate them.
August 29, 2025 at 3:34 pm #17358461
alenL
HI,
they aren't Divi native. I did use Filter Posts - Divi Ajax Filter module from Divi Engine.
August 29, 2025 at 10:48 pm #17358892
Bobby
Thank you for sharing!
I am not familiar with that plugin nor can I locate it in our compatible plugin list.
Thank you,
Bobby
August 31, 2025 at 11:35 am #17360390
alenL
Hi Bobby,
I did manage to solve that issue in meanwhile. I edited translation by directly editing page on frontend and it seems to work as expected now.
However, there is one more thing that bothers me.
I have custom post type "Homes" and I've created template for that posts using Theme Builder. Inside of template I have button "Contact Us" which is anchor link to contact form at the end of the page.
Anchor link works if there is "#kontakt" module_id, but WPML did translate module_id to "#contact" so anchor doesn't work anymore. I can't edit one by one house since they are using same template.
Is there any solution to this?
Example is: hidden link
Button "Send Inquiry".
August 31, 2025 at 11:50 am #17360395
alenL
Also, on the same page at form item "Do you have building plot" there is wrong translation. It should be "Yes" or "No".
September 2, 2025 at 6:28 pm #17367352
Bobby
Thank you for updating me! That is a great workaround and many times it is what we would recommend.
One thing to note and be aware of is when updating the default language it can possibly overwrite the change so you would just need to remember to re adjust it manually.
One way to prevent that is switching that specific page from using the Advanced Translation Editor to WordPress Editor
Related Documentation:
Regarding the field for #kontakt , I understand your concern and there a few ways we can address that.
1. Easiest is when transalting in the Advanced Transaltion Editor use the "search" function at the top and search for the link #kontakt, you will then be able to adjust the translation.
2. Another option is to tell WPML to ignore that field and not translate it, however, the problem that can arise there is that if it's a global link field that would cause the rest of the links to be ignored as well.
Would you be able to use #1 as a workaround and do it once or would you need to do this mutliple time for all Homes?
If possible to have access to the backend it would help me better assist as I might even be able to find the actual ID and create a config.xml file for it within WPML->Settings->Custom XML Configuration
September 7, 2025 at 6:46 pm #17382079
Bobby
1. Please go to WPML->Translation Management->Scroll down to Body Templates and locate All Katalog Kuca
2. Send to your self for translation
3. Access in the ATE editor and you will notice the button URL is showing the option to alter #contact or #Kontakt
See my screenshots attched.
