Translations not showing in Jet engine CPT admin column.
When creating a CPT make sure to enable relevant setting for admin columns and then make sure to turn it on from Screen Options in CPTs listing screen.
Relevant Documentation:
Last updated by nobord 1 year, 6 months ago.
Assisted by: Waqas Bin Hasan.
December 1, 2023 at 3:46 am #14968321
nobord
- Tell us what you are trying to do?
Translate Jet engine CPT
- Is there any documentation that you are following?
I activated the CPT in WPML settings.
The whole site is already translated.
I previously created and translated on this site the same posts on Jupiter theme's default portfolio post. I am migrating to Jet engine.
Could it be the reason why the CPT doesn't show the translations in admin column ?
Using :
- Jupiter theme
- Jet engine to create the CPT
- Elementor for the front end grids
December 1, 2023 at 5:04 am #14968517
nobord
The translations for jet CPT seems activated, I can add the translation from inside the post edit.
But its still not showing the wpml admin column.
December 1, 2023 at 9:51 am #14970873
Waqas Bin Hasan
WPML Supporter since 05/2014
Do you see "Language" option in "Screen Options" of CPT's posts listing screen? See attached for understanding. Please make sure that's turned on if available.
If you don't see that option, check by editing CPT's settings to find any suitable option. Also, check by creating a new CPT with JetEngine and see if you can find that languages column.
Please let me know and I'll try my best to further assist you on the matter.
Regards.
December 2, 2023 at 1:18 am #14976535
nobord
Hello Waqas,
Thank you for your good insights.
I dont have the languages screen option in my Projects cpt but i have it when creating a brand new jet cpt.
Need to understand why its not showing on the project cpt....
December 3, 2023 at 6:59 am #14979433
nobord
Found it in admin collumn.
It was not automatically added.
