- | 12:00 – 14:00 | 12:00 – 14:00 | 12:00 – 14:00 | 12:00 – 14:00 | 12:00 – 14:00 | - |
- | 17:00 – 21:00 | 17:00 – 21:00 | 17:00 – 21:00 | 17:00 – 21:00 | 17:00 – 21:00 | - |
This topic contains 19 replies, has 2 voices.
Last updated by fadiS-3 2 months, 1 week ago.
Assisted by: Bigul.
May 30, 2025 at 8:49 am #17091130 | |
fadiS-3 |
Background of the issue: hidden link Symptoms: Questions: |
May 30, 2025 at 3:25 pm #17092725 | |
Bigul WPML Supporter since 01/2013
Languages: English (English ) Timezone: Europe/Vienna (GMT+02:00) |
Hello, Welcome to the WPML support forum. I will do my best to help you resolve the issue. To help you faster, I've enabled debug information for this support ticket. Please see this link for how to get this information from your site and give it to us: http://wpml.org/faq/provide-debug-information-faster-support/ Just to confirm, are you trying to update the SKU value of the original product and its translations? Please note that SKU is considered a unique identifier. Do you have another unique identifier for each product that can be used instead? Also, have you imported the products previously — for example, using WP All Import or any other import tool? -- Bigul |
May 31, 2025 at 2:56 am #17093652 | |
fadiS-3 |
Hi, I have added the debug info for you to check out. are you trying to update the SKU value of the original product and its translations? - Now the issue is that the sku's are a vital part of the inventory management, and i need it to be there. So thats why im requesting your assistance to help me update the sku's without interrupting the products |
June 1, 2025 at 12:25 pm #17095357 | |
Hello, Thank you for the updates. This requires further checking. We assume you are referring to the following ticket. If not, please share the correct ticket or chat URL (of your previous discussion with us about importing products). This will greatly help us with our internal communication. https://wpml.org/forums/topic/import-products-3/ -- Bigul |
June 2, 2025 at 5:09 am #17096279 | |
fadiS-3 |
Hi, This is the ticket im referring to: https://wpml.org/forums/topic/need-help-with-uploading-products-in-both-english-and-araboc/ |
June 2, 2025 at 1:58 pm #17098236 | |
Hello, Thank you for the updates. I am consulting with our team for an expert opinion on this and will get back to you as soon as possible. Please wait. -- Bigul |
June 4, 2025 at 5:19 pm #17107707 | |
Hello, We have reviewed your case, and it’s great to know that the products are already connected correctly in both languages using the WPML Export and Import process. Since the SKUs were not included in the initial import, you can update them via a new import. Most import workflows support updating existing content by matching a unique identifier—ideally the same one used during the original import. So, please prepare a new import file that includes only the SKU field and the same unique identifier. This will ensure the existing products are matched correctly and updated with the new SKUs in both languages without affecting other data. Before proceeding, please make a full site backup. Then run the import and check whether the expected results are achieved. -- Bigul |
June 7, 2025 at 4:53 pm #17115737 | |
fadiS-3 |
Ok so to clarify, i need to export the products from this website, and then remove clear all fields except the id and only add the sku to them? Does this new import file include both english and arabic? |
June 9, 2025 at 7:30 am #17117168 | |
Hello, Thank you for the updates. Yes, you can export the products and keep only the ID and SKU columns in the file. After updating the SKUs, you can import the file back. This will only update the SKU of each product. The SKU is the same for both English and Arabic, so importing the file in the default language (English) is enough, and you can update Arabic translations after that. You don't need to import separately for Arabic unless you are using different SKUs for each language. Please try it after a full site backup and let us know your feedback. -- Bigul |
June 10, 2025 at 8:04 pm #17123544 | |
fadiS-3 |
Hi, ok so i will just import the english language products and update the sku's for them. So will the sku's automatically populate for the arabic language or i would need to do it manually. We need to keep in mind that there are over 600 sku's to be added. |
June 11, 2025 at 3:31 pm #17126975 | |
Hello, Thank you for the updates. What I meant is updating the Arabic product translations using the WPML Editor. Since you have a large number of products, you can also use the import process to update the SKUs for the Arabic products efficiently. -- Bigul |
June 12, 2025 at 12:35 am #17128078 | |
fadiS-3 |
Hello, Im sorry im not quite sure i understand the message on how to import sku's for arabic products. Are you able to share some sort of a screencase please for better understanding |
June 12, 2025 at 10:18 am #17129500 | |
Hello, Thank you for the updates. You can import the Arabic products the same way you import the English products. Currently, we don’t have a local copy to share a screencast with instructions. Do you have a staging/development site, a clone of the live site, where we can run the tests without affecting your production environment? -- Bigul |
June 16, 2025 at 12:56 pm #17138781 | |
Hello, Thank you for the updates. However, I had the following error while logging in. Please check. Error: The password you entered for the username *** is incorrect. Lost your password? Also, could you please share the import file you are using for further investigation? You can upload it to Google Drive and share the link. I have enabled the private option for your next reply. -- Bigul |
June 17, 2025 at 5:19 pm #17143540 | |
fadiS-3 |
Hi, please check the credentials again, they are correct. i tested them right now hidden link this contains the files to upload |
The topic ‘[Closed] Need help with product upload and’ is closed to new replies.
