Last updated by Dražen 8 months ago.
Assisted by: Dražen.
May 2, 2025 at 2:52 pm #16989935
evgenyV-2
I am using Elementor, ACF, and WPML for a multilingual website. I have a custom post type called 'officials' connected to product categories. These officials are salespeople responsible for specific product categories. On category pages, I display these salespeople using an Elementor loop with a custom filter. In the main language (Hebrew), it works well, but in the English version, the query to retrieve connected salespeople returns empty. I attempted debugging, but the query still returns nothing. The code snippet I used is:
elseif (is_product_category()) {
$term_id = get_queried_object_id();
$original_id = apply_filters('wpml_object_id', $term_id, 'product_cat', true, wpml_get_default_language());
$query->set('meta_query', array(
array(
'key' => 'connected_categories',
'value' => '"' .$original_id . '"',
'compare' => 'LIKE'
The query to retrieve connected salespeople in the English version of the site returns empty, despite the connection being visually set in the admin.
What am I doing wrong with the query in the English version?
Why does the query return empty for the English version but works in the main language?
May 6, 2025 at 8:28 am #17000086
Dražen
Thanks for contacting us.
As I can see from shared code you are getting original ID, while you should get translated ID of category. And then get translated post related to that translated category.
Please check:
- https://wpml.org/wpml-hook/wpml_object_id/
For example:
    // Get translated ID in the current language instead of default
    $translated_id = apply_filters('wpml_object_id', $term_id, 'product_cat', false, ICL_LANGUAGE_CODE);
        array(
            'value' => '"' . $translated_id . '"',
            'compare' => 'LIKE'
Let me know how it goes.
Drazen
May 6, 2025 at 8:35 pm #17003540
evgenyV-2
Hi Drazen
Thank you for answering. I tried both. The problem is that the function doesn't show any connections when in a translated language, as if they do not exist. I solved the problem by removing the connections between the original "officials" and their translations. Once I did this, everything started working as expected. It is obviously not the best solution, but it works.
Best,
Evgeny
May 7, 2025 at 6:26 am #17004369
Dražen
Hello Evgeny,
Glad to hear you found a workaround.
If you need further help and want us to check further, please create a staging site, and minimize your custom code, best would be WP default theme, Elementor, ACF and WPML plugins active.
Let me know.
Drazen
The topic ‘[Closed] I am using Elementor, ACF and WPML for a multilingual website, and have issues with custom filter’ is closed to new replies.
