This topic contains 10 replies, has 0 voices.
Last updated by Kor 3 days, 8 hours ago.
July 1, 2025 at 3:36 pm #17189367
Davide
I need the One Click Accessibility plugin to work with both Italian and English on my site hidden link. Currently, it only works in one language at a time, either Italian or English.
The One Click Accessibility plugin is not functioning in both Italian and English simultaneously.
How can I configure the One Click Accessibility plugin to support both Italian and English?
Is there a recent solution or update from WPML to address this issue?
July 2, 2025 at 12:47 am #17190402
WPML Supporter since 08/2022
To help speed up the support process, I've enabled a private message for submitting the debug information for this support ticket. Please follow these initial debugging steps:
https://wpml.org/faq/provide-debug-information-faster-support/
In short:
- Go to "WPML > Support > Debug Information" (link)
- Copy the Debug Information from there.
- Find the private field I activated and paste that information.
July 2, 2025 at 2:53 am #17190523
Davide
Hi Kor,
here are my debug information.
Cheers
Davide
July 2, 2025 at 6:35 am #17190850
Thanks for your reply. Could you please share some examples of the issue? Also, if possible, highlight it using screenshots and share the URL of the page in question.
While checking the debug info, I see that the WordPress Memory Limit is below the requirements. The minimum requirements are 128M, but we do recommend 256M and the debug information of your site shows it set to 40M. Please check this link for more details
https://wpml.org/home/minimum-requirements/.
You can increase it by adding the following code in your wp-config.php file, right before the /* That’s all, stop editing! Happy publishing. */ line:
define( 'WP_MEMORY_LIMIT', '128M' );
After adding the code you can confirm that the memory was changed correctly from WPML > Support > WordPress > Memory limit.
July 5, 2025 at 3:52 am #17203314
Davide
Hi Kor, sorry for taking longer to reply, I didn't understand at first I had to add both lines to the config.php file.
I can confirm now that I did and that warning is gone, the limit has increased accordingly.
July 7, 2025 at 1:14 am #17205820
July 7, 2025 at 7:46 am #17206639
Davide
The accessibility plugin its showing only in one language (in this case italian). I would like to see it in both languges, italian and english.
See screenshot below, the blue logo of accessibility plugin only show in one language.
The website url is: hidden link
I've done the mobile version as the pics are smaller and easier to view and compare, but it's exactely the same on desktop view.
Davide
July 7, 2025 at 3:42 pm #17210047
Thanks for your reply. I don’t see the accessibility option on either the desktop or mobile version in both languages. Is there something I need to do to make it appear?
July 14, 2025 at 8:07 am #17232031
Davide
Hi Kor,
you should see the ccessibility plugin ONLY in the italian language, in both mobile and desktop version.
I tested with gtmetrix and with a variety of browsers, and it is visibible without any problem, and no you don't need to do anything to make it appear.
The problem is (just in case we forgot what are we talking about) how to I make sure that the accessiblity plugin will be visible in english too? (as it is in italian).
thanks in advance for your precious help Kor.
Davide
July 14, 2025 at 8:11 am #17232065
Davide
sorruìy in the previous post id didn't load the screenshot
July 14, 2025 at 8:37 am #17232199
Thanks for your reply. I can see the issue now. I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
