Supporter timezone: Europe/Madrid (GMT+02:00)
Last updated by Carlos Rojas 9 months, 1 week ago.
Assisted by: Carlos Rojas.
December 20, 2024 at 1:00 pm #16534213
evgenyV-2
I'm translating a website using WPML, and some template parts aren't shown on some posts. The issue can be seen here: hidden link. I expected the header and footer to appear as they do in the German version: hidden link.
Not all template parts are shown on some posts in the translated version.
Why are some template parts not shown in the translated version?
How can I ensure the header and footer appear in the translated posts?
December 20, 2024 at 1:26 pm #16534375
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
1.- Could you describe, step by step, how the header is created or edited?
2.- Please share the access credentials to the site in your next message that I have set private. This will allow me to take a closer look at the site configuration. Don't forget to create a full site backup before sharing the credentials.
Carlos
December 20, 2024 at 2:39 pm #16534639
Carlos Rojas
Thank you for sharing the credentials.
Please share a URL to edit the header.
December 20, 2024 at 3:41 pm #16534823
evgenyV-2
December 22, 2024 at 1:18 pm #16537722
evgenyV-2
Hi. Is there any news for me? Thanks.
December 23, 2024 at 10:34 am #16539929
Carlos Rojas
Please go to WPML -> Translation Management -> Filter by 'Template part' -> Translate the Header and Footer and double-check if the issue disappeared.
December 26, 2024 at 11:40 am #16546726
evgenyV-2
Hi, Thanks for the advice. It mostly worked; I still have some issues, though. I say mostly because templates (specifically the one for the home page) aren't being loaded in translations. But I will try to solve this, but the problem is that I'm stuck on formatting markers. They aren't showing on the translations. They show on the side of the source but not on the side of the translation. And as a result, I cannot apply them and can't finish translating. How do I solve this?
December 26, 2024 at 12:30 pm #16546872
Carlos Rojas
Please share a link to a video reproducing the issue with the markers so I can have a better understanding.
December 26, 2024 at 4:06 pm #16547236
evgenyV-2
Of course. Attached. The issue is with the line breaks. I can't find a way to add them.
December 26, 2024 at 6:03 pm #16547464
Carlos Rojas
In this case, please duplicate the segment and then translate it. That way it will copy the HTML markers and it will be easy to translate.
December 26, 2024 at 10:18 pm #16547692
evgenyV-2
If you mean that I should copy the original text and then translate it, it doesn't work. These wpml_linebreaks do not get translated.
December 27, 2024 at 10:25 am #16548381
Carlos Rojas
I have consulted with my colleagues on the 2do tier of support and they recommended to escalate this ticket. I have escalated this ticket to our 2nd tier of support where our specialists are working on a solution. I will get back to you as soon as I get their feedback.
Thank you very much for your patience and understanding!
January 6, 2025 at 6:18 pm #16567361
evgenyV-2
Hello Carlos,
Any news from the 2nd tier?
Evgeny
January 7, 2025 at 9:57 am #16568766
Carlos Rojas
Hi Evgeny,
Our specialists are still working on a final solution to this issue. In the meantime, there is a workaround you can apply to avoid this issue:
- Edit the post/page/template in the original language
- Click on the icon to translate to the secondary language
- Once in the ATE interface (Advanced Translation Editor) -> Click on the Settings icon that appears on the top right
- Disable the option 'I prefer bigger segments'
- Save the changes
- Finish the translation and double-check if the issue disappeared
