- | 7:00 – 12:00 | 7:00 – 12:00 | 7:00 – 12:00 | 7:00 – 12:00 | 7:00 – 12:00 | - |
- | 13:00 – 15:00 | 13:00 – 15:00 | 13:00 – 15:00 | 13:00 – 15:00 | 13:00 – 15:00 | - |
Supporter timezone: Europe/Madrid (GMT+01:00)
Last updated by Carlos Rojas 3 weeks ago.
Assisted by: Carlos Rojas.
December 20, 2024 at 1:00 pm #16534213 | |
evgenyV-2 |
December 20, 2024 at 1:26 pm #16534375 | |
Carlos Rojas Supporter
Languages: English (English ) Spanish (Español ) Timezone: Europe/Madrid (GMT+01:00) |
Hello, 1.- Could you describe, step by step, how the header is created or edited? 2.- Please share the access credentials to the site in your next message that I have set private. This will allow me to take a closer look at the site configuration. Don't forget to create a full site backup before sharing the credentials. Looking forward to your message. |
December 20, 2024 at 2:39 pm #16534639 | |
Thank you for sharing the credentials. Please share a URL to edit the header. |
December 20, 2024 at 3:41 pm #16534823 | |
evgenyV-2 |
hidden link |
December 22, 2024 at 1:18 pm #16537722 | |
evgenyV-2 |
Hi. Is there any news for me? Thanks. |
December 23, 2024 at 10:34 am #16539929 | |
Hi there, Please go to WPML -> Translation Management -> Filter by 'Template part' -> Translate the Header and Footer and double-check if the issue disappeared. |
December 26, 2024 at 11:40 am #16546726 | |
evgenyV-2 |
Hi, Thanks for the advice. It mostly worked; I still have some issues, though. I say mostly because templates (specifically the one for the home page) aren't being loaded in translations. But I will try to solve this, but the problem is that I'm stuck on formatting markers. They aren't showing on the translations. They show on the side of the source but not on the side of the translation. And as a result, I cannot apply them and can't finish translating. How do I solve this? |
December 26, 2024 at 12:30 pm #16546872 | |
Please share a link to a video reproducing the issue with the markers so I can have a better understanding. |
December 26, 2024 at 4:06 pm #16547236 | |
evgenyV-2 |
Of course. Attached. The issue is with the line breaks. I can't find a way to add them. |
December 26, 2024 at 6:03 pm #16547464 | |
In this case, please duplicate the segment and then translate it. That way it will copy the HTML markers and it will be easy to translate. |
December 26, 2024 at 10:18 pm #16547692 | |
evgenyV-2 |
If you mean that I should copy the original text and then translate it, it doesn't work. These wpml_linebreaks do not get translated. |
December 27, 2024 at 10:25 am #16548381 | |
Hi there, I have consulted with my colleagues on the 2do tier of support and they recommended to escalate this ticket. I have escalated this ticket to our 2nd tier of support where our specialists are working on a solution. I will get back to you as soon as I get their feedback. Thank you very much for your patience and understanding! |
January 6, 2025 at 6:18 pm #16567361 | |
evgenyV-2 |
Hello Carlos, Any news from the 2nd tier? Evgeny |
January 7, 2025 at 9:57 am #16568766 | |
Hi Evgeny, Our specialists are still working on a final solution to this issue. In the meantime, there is a workaround you can apply to avoid this issue: |
