The client is unable to translate the 'read more' text on their website using WPML, and the strings are not appearing in the WPML String Translation.
We recommend trying two methods to resolve this issue:
Method 1:
Navigate to WPML > String Translation. At the bottom of the page, there is a checkbox labeled "Look for strings while pages are rendered". Enable this option, visit the front end of a page where the string appears, then return to WPML > String Translation and search for the string.
Method 2:
If the string is not found in WPML > String Translation, it might be categorized as an admin text string. You can find and translate admin text strings by following the guide here: Translate Admin and Settings Strings
Related documentation can be found here:
If these solutions do not resolve your issue or seem outdated, we highly recommend checking related known issues at WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML Support Forum.
Last updated by Mihai Apetrei 9 months, 2 weeks ago.
Assisted by: Mihai Apetrei.
October 1, 2024 at 10:46 am #16239754
jorisR-3
I am trying to translate the 'read more' text on this website hidden link and the strings are not showing up anywhere. I have already tried all the documentation.
Some Uncode parts are not translated.
How can I translate the 'read more' text on my website?
Why are the strings not showing up in WPML?
Page URL with issue: hidden link
October 1, 2024 at 12:46 pm #16240477
Mihai Apetrei
WPML Supporter since 03/2018
Hi there.
I am not sure which exact steps you have followed but the proper way to translate strings depends a lot on how they have been implemented inside the theme/plugin.
Please try both methods that I will mentione below and see if any of them resolves the issue.
Method 1:
Go to WPML > String Translation and at the bottom of the page you will find a checkbox called "Look for strings while pages are rendered". You can enable (check) that and then go to the front end to a page where you have that string showing up and then go back to WPML > String Translation and search for that string and see if it now shows up.
Method 2: If you can't find them inside the WPML > String Translation, they might be added as admin text strings.
This should be the normal process to find and translate admin text strings:
https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/#translate-admin-and-settings-strings
Please let us know how that goes.
Related documentation:
Kind regards,
Mihai Apetrei
