You need to translate elements like headers and footers created with GeneratePress and Blocks.
We recommend following our detailed guide on how to translate these elements using WPML. You can find the guide here: Translating GeneratePress Theme Using WPML.
If this solution does not apply to your case, or if it seems outdated, please check the related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket if you need further assistance. You can do so at WPML support forum.
Last updated by Andrey 1 year, 1 month ago.
Assisted by: Andrey.
May 30, 2024 at 7:25 am #15686139
henkt-2
Hi Andrey,
Can you tell me how I can translate elements (e.g. headers, footers, etc) that I've made with GeneratePress and Blocks. What's the best-practice to translate these?
May 30, 2024 at 7:27 am #15686158
Andrey
WPML Supporter since 06/2013
We have a guide that can help you translate these elements. Please follow it here: https://wpml.org/documentation/theme-compatibility/translating-generatepress-theme-using-wpml/.
