Last updated by Alejandro 4 years, 10 months ago.
Assisted by: Alejandro.
August 24, 2020 at 3:38 pm #6861221
ralitzaW
Hi!
I have two problems with translated things on my site.
The first one is the footer - in English is showing, in bulgarian also shows the english version - hidden link or here - hidden link
The second problem is bigger and it is with ACF Pro. In bulgarian version there is one extra field, but in english it doesn't want to show it.
BG - hidden link
EN - hidden link
This is the only page that i could run on it - hidden link
Other pages don't show it.
The theme is Twenty Nineteen
New threads created by Alejandro and linked to this one are listed below:
https://wpml.org/forums/topic/cant-translate-my-footer-correctly/
August 25, 2020 at 1:00 pm #6868723
Alejandro
WPML Supporter since 02/2018
Hello.
I'll probably need to split this ticket because we can only handle one topic per ticket. However before i do that i'd like to have more information on your first request:
How are the footer elements added to the footer? do they come from the oxygen theme, are they widgets? or something else?
This will help me understand how to continue with this.
About ACF, could you please confirm you followed this guide while setting ACF up with WPML?: https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/
If you didn't then i'd kindly ask you to check it, specially the part about configuring Repeater fields, flexible fields and other layout types of fields (in short, they should be set to "copy") and then when everything's configured please try the following:
1) Make a change to the post/page where you have this problem in the original language (even a character added/removed from the title will do)
2) Save it
3) Update the translation and check if the field is now there.
August 25, 2020 at 2:43 pm #6869703
ralitzaW
Hi! With ACF i fixed the problem but with footer still can't.
August 25, 2020 at 2:52 pm #6869791
Alejandro
I'm glad the ACF issue is solved. I created another ticket for the Footer issue. please answer it there.
In the meantime i'll close this ticket since it has a topic that has already been solved.
Regards and see you in the other ticket
