In this tutorial, you will learn how to set up the Smush plugin to optimize images on your multilingual site powered by WPML.
Getting started
Make sure that you have activated the Smush plugin by navigating to Plugins → Installed Plugins.
Also, make sure that you have activated the WPML Multilingual CMS and WPML String Translation plugins. In case you want to have different images for the pages that you will translate, please activate the Media Translation plugin.
Create your own team of local translators from the Translation Roles tab in Translation Management and assign translation jobs to them.
Setting Smush on multilingual sites
The Multilingual CMS plugin allows you to translate the media metadata such as the title, Alt text, and caption while translating the page or post content. You can also use a different image for the translation via the WPML Media Translation add-on. You can find more information about this in our guide about Media Translation.
Enabling automatic compression
In Smush settings, you can enable the feature that automatically compresses the default language image. This will also compress images in secondary languages (in case you’re using different images for translations).
To enable this option, go to Smush → Dashboard and under the Settings section, enable the Automatically compress my images on upload option.
Disabling automatic compression
If you disable automatic compression, you will need to compress the images (attachments) manually. You can do this by navigating to Smush → Dashboard andunder the Bulk Smush section, click the BULK SMUSH NOW button.
Clicking the bulk smush now button to optimize the images manually
Whether you are using the same images across translations or different ones, the Smush plugin will compress all the images.
Need help?
Need help with optimizing your images using Smush on WPML multilingual sites? visit WPML’s support forum.
