I am trying to use WooCommerce Bookings with WPML, but I encountered a problem with duplicates in my booking system. After contacting WooCommerce support, I found out that WPML causes duplicated values in the cart, affecting booking calculations. I tried changing settings in the WooCommerce Multilingual & Multicurrency tab, specifically setting 'Switching languages when there are items in the cart' and 'Switching currencies when there are items in the cart' to 'Prompt for a confirmation and reset the cart', but the issue persists. The issue can be seen on this page: hidden link
The booking system creates duplicated values in the cart, causing issues in booking calculations. When I reserve 69 persons for a specific date and try to book the remaining 1 spot, the system incorrectly marks the day as fully reserved.
How can I resolve the issue of duplicated values in the cart caused by WPML?
Why does disabling WPML make the booking system work correctly?
Languages: English (English )Spanish (Español )Italian (Italiano )
Our second tier has identified the problem (when a booking is made it is duplicated to other languages with the same number of people, so if you book 20 people in English it will also create a booking for 20 people in Spanish for the same date.
The issue has been escalated to the compatibility team.
I will let you know when I have some news.
