The client was experiencing issues with the Advanced Translation Editor (ATE) where symbols such as were being replaced by placeholders like 'encoded_tag_open' and 'encoded_tag_closed'. This was preventing the client from seeing the actual text and copying the translated text to add these markers afterwards.
We identified that the ATE was encoding these symbols to prevent them from being interpreted as HTML, which is standard behavior to avoid breaking the XML during content transfer. The client was advised to use the previous version of ATE (Gen2), which does not present this issue, until a fix for the latest version (Gen3) is released. This fix is currently in testing and expected to be included in the upcoming ATE release. We apologize for any inconvenience and are working on improvements.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please do not hesitate to open a new support ticket at WPML support forum.
This topic contains 24 replies, has 2 voices.
Last updated by Carlos Rojas 8 months, 1 week ago.
Assisted by: Carlos Rojas.
October 30, 2024 at 1:46 am #16344527
elkeS-3
I am trying to translate some texts containing > and and <, they are defined as encoded_tag_closed and encoded_tag_open in ACE. Link to a page where the issue can be seen: hidden link
The symbols are replaced by encoded_tag_closed etc. I don't see the text - just these 'encoded_tag...'. The keyboard shortcut for accepting them is shown as 'Alt+1', but after rolling back to a previous version, I found that it's 'Alt+Ctrl+1'. It's not possible to copy the translated text and to add these markers afterwards.
Why are the symbols replaced by encoded_tag_closed and encoded_tag_open?
How can I copy the translated text and add these markers afterwards?
October 31, 2024 at 8:34 am #16350100
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
According to the description of this behavior, it seems that ATE is encoding the opening and closing tags so it doesn't get interpreted as HTML. The same way it creates tags for 'bold' or 'H1' tags.
In any case, could you share a screenshot of the original content with the tags and another screenshot of what you see in ATE? This will help me to better understand this scenario.
Carlos
October 31, 2024 at 9:55 am #16350478
elkeS-3
Hi Carlos,
I have added some screenshots.
The site's theme is DIVI. I have done screenshots of the text in visual and text mode.
In the ATE screenshot you can see that the "plain" > is interpreted as encoded_tag_closed.
As a remark: this site is a copy of the already existing site gts-keramik.de - and there I have these texts already translated - some time ago.
And last but not least: the shown shortcut "Alt + 1" is wrong - I can only save translation, if I mark the tag and confirm with "Alt + Ctrl + 1".
Elke
October 31, 2024 at 12:25 pm #16351357
Carlos Rojas
Hi Elke,
Thank you very much for sharing this information
I consulted my colleagues about the tags, and this is the expected behavior because the opening and closing tags break the XML that is sent with the content, that's why they are substituted by a tag in ATE.
Regarding the Alt+1, I'll have to check that in ATE. Could you share the access credentials to the site in your next message and share the URL of a page where I can see the Alt+1 issue?
October 31, 2024 at 1:00 pm #16351506
elkeS-3
For wordpress login please use the following URL:
The issue can be found on hidden link.
I have marked some of the modules with text "ISSUE", so you can identify them quicker.
Is there any way to say "hey, this is just text, no tag"? I find it really confusing that these items "disappear" ...
November 4, 2024 at 8:25 am #16359221
Carlos Rojas
Good morning!
I kindly ask you to share the access credentials because the link expired. I have set your next answer private so you can securely share credentials.
I am looking forward to your message.
November 4, 2024 at 9:00 am #16359380
elkeS-3
Good Morning, Carlos!
Sorry for that ... here's a new link:
November 4, 2024 at 9:43 am #16359661
Carlos Rojas
Thanks for the new link 🙂
I visited the page hidden link but I can't find any text with the string 'ISSUE'. Did you remove them?
November 4, 2024 at 10:04 am #16359834
elkeS-3
sorry for the confusion:
I referred to the naming of the modules in the backend when editing the page hidden link. Please have a look at the screenshot.
In ATE the entries are "empty", waiting for translation - see the other screenshot 😉
November 4, 2024 at 10:42 am #16360243
Carlos Rojas
Thank you for the clarification 🙂
I'm consulting with my colleagues this issue and I will get back to you as soon as I get an answer.
November 4, 2024 at 10:58 am #16360323
Carlos Rojas
I have consulted my colleagues and we have checked all the cases, everything is working as expected, including the Alt+1 to add the tag
November 4, 2024 at 11:06 am #16360448
Carlos Rojas
After talking to my colleagues about some other behaviors we found, I decided to escalate this ticket to our 2nd tier of support so our development team can take a closer look at this and try to find a better solution for future releases.
November 4, 2024 at 11:38 am #16360582
elkeS-3
I have to admit - I'm confused: everything is much better in this environment now ...
It is immediately noticeable that the keyboard shortcut for the encoded hint is now correct (see the attached screenshot and the one from October 31) - and the functionality is also there.
But on the production environment the problem is still there - although all plugins etc. are at the same level.
Have you changed any settings?
Screenshot 2024-11-04 at 12-15-24 Advanced Translation Editor - WPML - Encoded.png
November 4, 2024 at 12:21 pm #16360924
Carlos Rojas
Could you share the URL of ATE when translating the content? I don't see those changes
November 4, 2024 at 1:07 pm #16361141
elkeS-3
Hmm ... Is it possible that it's depending on the browser? Do you work with Chrome?
I just checked with both credentials: in Firefox it's with Ctrl, in Chrome without
Nevertheless this is the link:
