9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 - -
14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 - -
Last updated by Christopher Amirian 2 months ago.
March 11, 2026 at 8:35 am
Niko
For some reason the added attributes are not added for the translated woocommerce product.
Here is the issue: hidden link
March 11, 2026 at 1:32 pm #17888939
Christopher Amirian
WPML Supporter since 07/2020
I tried the same thing on a clean installation of WordPress, WPML and Woocomemrce.
If you login here:
And then go to this product:
And check the translation which I used the Native WP Editor it shows the variations correctly.
This shows there is no inherit code issue in WPML for this and it is related to your installation.
I am still working to see if I can find what might be the problem in your installation.
March 12, 2026 at 5:38 am #17890737
Christopher Amirian
Ok,
I deactivated all plugins except:
. Woocommerce
. Woocommerce Multilingual
. WPML Multilingual CMS
. WPML String Translation
Now if you check the sample product:
You will see that the variations work ok.
Please activate the plugins one by one to find out which plugin causes the issue.
The topic ‘[Closed] Added attribute values are not added for the translated product’ is closed to new replies.
