You are using WPML with ACF Multilingual and have encountered an issue where the custom post type's permalink works as expected in the primary language (English), but the permalink structure is broken in a secondary language.
This behavior might be expected due to the design of ACF's custom post types (CPT) functionality, which may not fully support multilingual permalink structures. We recommend setting up a staging environment to conduct further tests and identify a possible solution. If this issue persists, check if the post is published as a Draft.
100% of people find this useful.
Last updated by takahiroK-2 1 year, 6 months ago.
Assisted by: Marcel.
October 25, 2024 at 5:23 am #16329018
takahiroK-2
We are using WPML + ACF Multilingual and we found a problem. ACF now supports the creation and management of custom post types and taxonomies. We would like to use its custom permalink function for some post types. Link to a page where the issue can be seen: hidden link
The custom post in English (the primary language) can be referred to with the customized URL as we expected. However, the permalink structure for the custom post in a secondary language is completely broken. You can see the broken URL in the language switcher.
Who is responsible for this issue, WP Engine or onTheGoSystems?
October 25, 2024 at 4:33 pm #16331705
Marcel
I can't load the language switcher in any secondary language. Are the languages marked as private? So basically, do you mean the archive slug?
It's not possible to translate this one, please see: https://wpml.org/forums/topic/acf-custom-post-type-slug-translation/.
The reasons for this are mentioned here: https://wpml.org/documentation/support/translating-slugs-for-custom-post-type-archives/. In that case, we can't control the behaviour from ACF and how the CPT was created.
Best Regards,
Marcel
October 28, 2024 at 6:57 am #16335950
takahiroK-2
The articles you cited are regarding the custom archive slug.
But the issue I reported is regarding the custom permalink of single custom posts.
Besides, when we use another plugin, Custom Post Type UI, it works perfect.
Sorry that the translated post was private.
The permalink of the Chinese custom post looks like:
We hope this issue can be fixed.
Thank you for your support any way.
October 28, 2024 at 8:45 am #16336375
Marcel
This is likely expected behavior when using ACF’s CPT functionality, as some components aren’t supported due to how ACF CPTs are designed. Do you have a staging environment where we could run some tests?
Marcel
October 28, 2024 at 8:58 am #16336505
takahiroK-2
Oops! It was our mistake. The Chinese post is not even a private post but is a draft.
Sorry for making an inappropriate report.
