Last updated by Kor 1 month, 1 week ago.
June 20, 2025 at 8:39 am #17153378
kalinV
I’m using WPML for multilingual support on my website hidden link and I would like to translate an Advanced Slider element from the ElementsKit plugin (used with Elementor). I tried adding a custom XML configuration under WPML → Settings → Custom XML Configuration, but it didn’t work. Example fields I’m trying to translate: title, description, button text, and link.
WPML does not recognize the content inside the Advanced Slider and it doesn’t show up in the Translation Editor.
Is the Advanced Slider widget from ElementsKit officially supported?
What is the recommended XML configuration for this widget?
Is there an alternative method to make it translatable via WPML?
June 23, 2025 at 6:48 am #17158092
WPML Supporter since 08/2022
Thanks for contacting us. Could you share the full XML configuration that is generated by the multilingual-tools plugin? If it's too long, please share it on pastebin.com
The topic ‘[Closed] Advanced Slider from ElementsKit not translatable with WPML’ is closed to new replies.
