Last updated by salaheddineS 4 weeks, 1 day ago.
April 2, 2026 at 7:37 pm #17946935
salaheddineS
Hi
After installing wpml, menu is not showing for english and french but is showing for arabic, I am using houzez themes with elementor
Thanks’
April 2, 2026 at 8:00 pm #17946950
salaheddineS
Please after installing wpml, menu in main lnaguage English and French are not showing, only arbic is showing, I am using Houzez theme with Elementor
Can you please help me?
Thanks’
Salaheddine
April 3, 2026 at 9:50 am #17947679
Marcel
Hi Salaheddine,
before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process.
Did you translated the menu as described here https://wpml.org/documentation/getting-started-guide/translating-menus/? Which method did you used?
Best Regards,
Marcel
April 4, 2026 at 6:23 am #17948761
salaheddineS
Hi Marcel,
I managed to get it working after tried couple of times, the header and the footer are Elementor Tempalate, what I did I removed all menus and create theme again and is start working, it seems is due to exiting menu after I migrated from Polylang to WPML.
Thank you for your help.
Salaheddine
