The client was unable to load the AI Translation section in WPML and could not map the default language, German, to a supported language for automatic translation. The 'Map language' button showed no options, and the Language Mapping column was not displayed.
1. **Increase the WordPress Memory Limit**: The client was advised to increase the memory limit to at least 128MB, ideally 256MB, by modifying the
wp-config.php
file.
2. **Clear WPML's Cache**: The client was instructed to clear WPML's internal cache through WPML → Support → Troubleshooting.
3. **Update AI Translation Settings**: After increasing the memory limit and clearing the cache, the client needed to check the AI Translation settings in WPML → Settings to ensure the system could properly display mapping options.
If the solution provided does not resolve your issue or seems outdated, we recommend opening a new support ticket. We also advise checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
Last updated by Carlos Rojas 5 months, 3 weeks ago.
Assisted by: Carlos Rojas.
October 30, 2025 at 8:11 am #17531459
Sandra
I have WPML installed and would like to use the AI features. Unfortunately, the AI section doesn’t load. In the settings, I get a message about mapping my default language, German, to a supported language for automatic translation.
The AI section doesn’t load. The message in settings says: 'Your default language, German, must be mapped to a supported language to use automatic translation.' When I click the 'Map language' button, there’s no option available, and the column for Language Mapping isn’t displayed.
Why is the AI section not loading?
How can I map my default language, German, to a supported language for automatic translation?
Why is there no option available when I click the 'Map language' button?
Why is the Language Mapping column not displayed?
October 30, 2025 at 12:34 pm #17532644
Carlos Rojas
WPML Supporter since 03/2017
Please share the access credentials to the site in your next message, which I have set private. This will allow me to reproduce the issue and check the configuration.
November 3, 2025 at 10:12 am #17540253
Carlos Rojas
Hi Sandra,
Thank you very much for sharing the credentials requested.
I have updated the WordPress Memory limit for you, so that is solved.
Also, the problem with the automatic translation is solved. The only part missing was the information about your site in WPML -> Settings -> Automatic translation -> Context and Target Audience. I added temporary information, but I kindly ask you to add the correct info so the AI can make a better translation.
Can you confirm that the issue was solved?
November 7, 2025 at 5:42 pm #17558186
Sandra
Thanks for your support. I still can't get the fact, that the memory_limit was to low, but I don't care, because the problem is solved. Thanks a lot!
November 10, 2025 at 9:06 am #17561018
Carlos Rojas
I'm happy to hear that the issue was solved!
Please don't hesitate to contact us if you need our assistance in the future with WPML. We are here to help 🙂
