The customer translated the placeholder 'Search here..' from the 'Ajax Search Lite' plugin into French, English, and traditional Chinese. The default language of the site is French. Despite translating the placeholder into multiple languages, the French translation ('Chercher') appears in all languages instead of the respective translations. This issue corrects itself when the 'Auto-register strings' option is activated but reverts back to displaying the French translation when the option is deactivated.
If you're experiencing this issue, we recommend you try the following steps:
- Go to WPML > Theme and plugin localization
- Check the "Automatically load the theme's .mo file using 'load_textdomain'" box
- Add the textdomain (probably "ajax-search-lite and/or ajax-search-pro") to the "Enter textdomain" field then save
- Scroll down and scan the theme/plugin
- Go to WPML > Support > Troubleshooting
- Click on "Show custom MO Files Pre-generation dialog box"
- Refresh the page (It should display the MO files dialog box)
- Regenerate the MO Files
If this solution does not resolve the issue, it might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by Mateus Getulio 1 year, 1 month ago.
Assisted by: Mateus Getulio.
May 20, 2024 at 11:01 am #15645152
elyesZ
I translated the placeholder 'Search here..' from the 'Ajax Search Lite' plugin into French and English, which worked fine initially. I then added a traditional Chinese translation for the same placeholder. The default language of the site is French.
Why does the French translation appear in all languages despite having translations for each?
How can I fix the issue so that each language displays its respective translation without having to keep the 'Auto-register strings' option activated?
May 20, 2024 at 7:26 pm #15647283
Mateus Getulio
Hello, welcome to the WPML support Forum!
Please try the following procedure to try to fix this issue:
- Add the textdomain (probably "ajax-search-lite and/or ajax-search-pro") of the string to "Enter textdomain" field then save
- Go to WPML >Support > Troubleshooting
If it doesn't work, I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
