You are trying to define ARIA for the menu using Elementor, but it doesn't work despite your efforts. The markup generated by the plugin does not reflect the changes you attempt to make.
We are aware of this issue and are planning to release a fix in WPML version 4.9.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket at WPML support forum.
Last updated by Otto 3 months, 2 weeks ago.
Assisted by: Otto.
January 9, 2026 at 3:25 pm #17716646
harunG
On the PageSpeed screen, I’m being told to define ARIA for the menu. I try to add it from Elementor → Advanced → Attributes, but it doesn’t work no matter what I do.
The markup generated by the plugin looks like this:
<li class="menu-item wpml-ls-slot-3 wpml-ls-item wpml-ls-item-en wpml-ls-current-language wpml-ls-menu-item wpml-ls-first-item menu-item-type-wpml_ls_menu_item menu-item-object-wpml_ls_menu_item menu-item-has-children menu-item-wpml-ls-3-en">
hidden link" role="menuitem" class="elementor-item">
<img …
how woud i solve this issue?
January 9, 2026 at 4:37 pm #17716844
harunG
It seems that the issue is caused by the language switcher, and because an ARIA label cannot be added, PageSpeed is showing an accessibility error.
English
Русский
Français
Português
Español
Deutsch
العربية
हिन्दी
বাংলাদেশ
January 9, 2026 at 6:23 pm #17717078
Otto
Thanks for reporting this. We are aiming to release a fix for this in WPML 4.9.
You can already give it a try with the beta version:
https://wpml.org/faq/how-to-install-beta-and-development-versions-of-wpml/
Let me know how it goes, please.
Best Regards,
Otto
January 9, 2026 at 6:55 pm #17717099
harunG
Hello Otto, thank you very much for your reply.
When I switch to the beta version, I won’t experience any changes in translations or edits, right?
If it’s very risky and version 4.9 will be released soon, I can wait until then.
January 9, 2026 at 7:23 pm #17717222
Otto
If you don't have a staging environment, I suggest you to avoid switching to the beta version.
WPML 4.9, is expected (although I can't guarantee) to be released during the current month. So I suggest waiting for it.
Best Regards,
Otto
January 9, 2026 at 8:51 pm #17717355
harunG
Hello Otto,
Yes, I completely agree with you. In that case, I will wait for the release of version 4.9.
I hope that this issue will be fully resolved with the new version. Thank you very much for the information and clarification.
Wishing you a pleasant weekend.
Harun
January 12, 2026 at 11:51 am #17721323
Otto
Thanks 🙂
