The client is trying to translate product attribute labels in WPML and encounters issues in both String translation and Taxonomy translation. The taxonomy general name is not plural and includes an untranslated English 'Product' prefix, which cannot be corrected through the UI.
To remove the 'Product' prefix from the taxonomy general name and manually add the plural form of the taxonomy singular name, we recommend using a custom filter hook in WooCommerce. Here is the code you can use:
add_filter( 'woocommerce_product_attribute_taxonomy_name', 'custom_woocommerce_attribute_label_plural', 10, 2 );
function custom_woocommerce_attribute_label_plural( $taxonomy_name, $taxonomy ) {
    if ( 'pa_your_attribute' === $taxonomy ) { // Replace 'pa_your_attribute' with the actual attribute taxonomy name
        // Return the custom label you want
        return 'Label'; // Replace with your desired label
    return $taxonomy_name;
This code will change the appearance of the label on the frontend but not in the wp-admin. Alternatively, you could register the original taxonomy in English and translate it into German.
If this solution does not resolve your issue or seems outdated, please check the related known issues, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. If needed, do not hesitate to open a new support ticket.
0% of people find this useful.
Last updated by Andreas W. 5 months ago.
January 23, 2025 at 11:21 am #16627419
frederikB-5
I am trying to translate product attribute labels in WPML. I see issue in both String translation and Taxonomy translation. The problem is visible in String translation: hidden link and in Taxonomy translation: hidden link
The taxonomy general name is not a plural and includes an untranslated English 'Product' prefix. This cannot be corrected through the UI. Attempts to delete the taxonomy general name result in it being regenerated when using Taxonomy translation.
How can I remove the 'Product' prefix from the taxonomy general name?
Is there a way to manually add the plural form of the taxonomy singular name without the automatic generation?
January 25, 2025 at 9:33 pm #16633961
This is WooCommerce default behavior.
To overwrite this label you can use the following hook:
This filter hook will only change the appearance of the label on Frontend, not on wp-admin.
The alternative would be registering the original taxonomy in English and translating it into German.
