Client is unable to see the translated postcards element category filters on the English version of their website. The filters are not displaying, and manual fixes are not permanent as they get reset randomly.
If you're experiencing issues with translating postcards element category filters and they are not displaying on your translated pages, we recommend adding custom XML configuration to your WPML settings. Here are the steps to follow:
1. Navigate to WPML -> Settings.
2. Add the following code to the Custom XML Configuration section:
<wpml>
  <shortcode>
    <tag>fusion_post_cards</tag>
    <attributes>
      <attribute type="media-ids">post_card</attribute>
      <attribute type="taxonomy-ids">include_product_cat</attribute>
    </attributes>
  </shortcode>
</wpml>
3. If you already have existing content in the Custom XML Configuration, ensure you add this within the section.
4. Update the page in the original language that contains the postcard.
5. Edit the translation and check if the content appears in the translation editor. If not, use the search function at the top of the advanced translation editor.
6. After saving the translation, verify if the translation is visible on the frontend.
For more details on how to use custom XML configurations, please refer to our documentation: WPML language configuration files.
If this solution doesn't seem relevant to your issue, please don't hesitate to open a new support ticket with us for further assistance.
This topic contains 7 replies, has 3 voices.
Last updated by Lauren 1 year, 7 months ago.
Assisted by: Lauren.
November 28, 2023 at 12:29 pm #14939123
dosvisual.com
I am trying to: translate to ENG the postcards element category filters
I expected to see: The postcards filters on the ENG version too (Milongas / CLASSES / PACKS + HOTEL)
Instead, I got: The filter is not displaying at all. I´m using the advanced translator and the page is translated completly. Actually, I´ve been fixing this by Editing the ENG page and adding the categories manually. The problem is this fix is not permanent, it gets reset randomly.
November 28, 2023 at 2:44 pm #14941035
dosvisual.com
p.s> the website is under maintenance right now so you´ll need a user to see the issue. I see no private fields to provide that information..
November 29, 2023 at 2:38 am #14945741
Bobby
WPML Supporter since 04/2015
Thank you for the above information, private field reply has been enabled
November 29, 2023 at 11:38 pm #14956895
Bobby
I can verify that indeed the category options are missing in the backend when i review the Avada element.
When you fix this manually, I suppose it reverts after you make a change to the default language correct?
If possible please try this with Workaround 2 and let me know you results
https://wpml.org/errata/avada-library-element-type-not-copied-during-manual-translation/
November 30, 2023 at 7:42 pm #14967047
dosvisual.com
Hi Bobby
Thanks for the suggestion.
The instructions on that link do not correspond to the issue I´m facing...
"Overview of the issue
When manually translating an Avada Library Element using the WordPress editor, the element’s type (e.g., “Container”) isn’t carried over to the translated version. Consequently, the translated element is always identified as a Template type.
Duplicating to other languages or translated using the Advanced Translation Editor (ATE) don’t present this issue."
The postcard element on /inscripciones// and /en/registrations/ was not on the library..
Just in case I saved it and followed the steps, the filters are still not displaying :/
December 5, 2023 at 12:46 am #14992073
Bobby
Correct, while they do not directly there was a chance the 2 were connected, thank you for testing the workaround and updating me.
I am escalating this thread to our 2nd tier support and they will take a look at this issue.
You will be notified as soon as new information is available.
Thank you,
Bobby
December 12, 2023 at 7:21 pm #15049279
dosvisual.com
Thanks Bobby
Are there any updates on this?
December 13, 2023 at 6:44 pm #15058197
Lauren
WPML Supporter since 10/2015
Hi there, Bobby is off for a few days so I'm stepping in to hellp out. Please add the following to your WPML -> Settings -> Custom XML configuration. If you already have content there, make sure you add this to the shortcode section. If not, make sure you use the <wpml> opening and closing tags as outlined here: https://wpml.org/documentation/support/language-configuration-files/
Code to add:
<shortcode>
      <attributes>
      </attributes>
    </shortcode>
After adding this to the custom XML configuration, update the page in the original language that has the postcard. Then, edit the translation and you should see this content in the translation editor. If you don't see it, please use the search at the top of the advanced translation editor and let me know if you see it there. Once you save the translation, check and see if the translation shows on the frontend.
December 14, 2023 at 2:38 pm #15065713
dosvisual.com
It worked Lauren, thanks a lot 🙂
