Last updated by frederikK-4 3 years ago.
Assisted by: Long Nguyen.
| Author | Posts |
| November 28, 2022 at 1:46 pm #12547457 | |
frederikK-4 |
Barn2 Woocommerce Sample Product and Overnight's WooCommerce PDF Invoices & Packing Slips issue |
| November 28, 2022 at 2:25 pm #12547777 | |
frederikK-4 |
So I've installed everything and this is how to replicate the issue: 1) Go to this product: hidden link Now to see the correct behaviour, disable the "WooCommerce Multilingual & Multicurrency" plugin and repeat above steps. Note that in step 5 and 6 the word "Sample" still shows. This is how the plugin should behave. So somehow the "WooCommerce Multilingual & Multicurrency" plugin interferes with the behaviour of Barn2's plugin. Kindly have a look at what is causing this. |
| November 29, 2022 at 4:10 pm #12556557 | |
frederikK-4 |
Issue still not resolved. WPML please have a look at this issue. |
| November 30, 2022 at 7:36 am #12560041 | |
Long Nguyen WPML Supporter since 02/2022
Languages: English (English ) Timezone: Asia/Ho_Chi_Minh (GMT+07:00) |
Hi there, Thank you for contacting WPML support, I'd be happy to help you on this issue. I see that happens on the Order Received page in the frontend and the Orders page in the backend. It looks like a compatibility issue with WooCommerce Sample Product and I'm discussing this issue with my colleagues and get back to you if I have some information. Thanks for your patience. |
| November 30, 2022 at 9:39 am #12561277 | |
frederikK-4 |
Hello, Kind regards, Frederik |
| December 1, 2022 at 9:28 am #12568877 | |
Hi, Thanks for your feedback. I've escalated this issue to our Compatibility team. I'll update you as soon as I have something to share. Thanks. |
| December 1, 2022 at 12:48 pm #12570841 | |
frederikK-4 |
Thank you. Looking forward to the update. |
| December 7, 2022 at 2:50 am #12603383 | |
Hi, I got some news from our 2nd tier supporter. You can try this workaround on your site to fix this issue. ❌ IMPORTANT: Please backup your database and website before proceeding ❌ Access your hosting/server and edit the file wp-content/plugins/woocommerce-multilingual/inc/class-wcml-orders.php, on line 197 with WCML version 5.1.0 or line 187 with WCML version 5.0.2 $item->set_name( get_post( $translated_product_id )->post_title ); replace it with
if ( ! class_exists('\Barn2\Plugin\WC_Product_Sample\Sample') ) {
Note: you might need to re-update the code if there is an update of the WCML plugin. This plugin is also not in our list of compatible plugins so I'd recommend that they join our Go Global program (https://wpml.org/documentation/support/go-global-program/) or you can ask them to send a request to us where our Compatibility developers will help them make their product compatible with WPML. Look forward to your reply. Thanks |
