You are using a multilingual WooCommerce website with WPML and a WooCommerce bundled products plugin. After recent updates, when you add or update a product in German, the bundled product disappears. Additionally, certain custom fields were set to 'don't translate' which should have been set to 'copy'.
First, ensure that the custom fields _wc_pb_aggregate_weight, _wc_pb_bundled_items_stock_sync_status, _wc_pb_sold_individually_context, and _wc_pb_virtual_bundle are set to 'copy'. This adjustment should resolve the issue with disappearing bundled products when updating in German.
For updating all products at once, if you use automatic translation, resend everything to translation. Alternatively, you can use a bulk update feature or a plugin to update the original products in bulk, then switch languages and perform the bulk update again.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket.
This topic contains 11 replies, has 0 voices.
Last updated by ziga pipan 7 months ago.
Assisted by: Laura.
August 14, 2025 at 11:45 am #17320807
ziga pipan
I have a multilingual WooCommerce website using WPML. I also use a Woocommerce bundled products plugin. The plugin works fine in the original language, but issues arise when adding products in German.
When I add a product in German and update it, the bundled product disappears. This issue started occurring after recent updates.
Why do bundled products disappear when updating in German?
Is there a known issue with WPML and bundled products?
Do I need to add XML to fix this issue?
August 18, 2025 at 8:54 am #17326663
Laura
WPML Supporter since 05/2018
Thanks for contacting us.
Could you please provide a link where I can see the issue?
August 18, 2025 at 9:15 am #17326834
ziga pipan
original language
german language
video recording
August 18, 2025 at 1:23 pm #17328050
Laura
The bundled products should be copied from the original. Did you ever change the default language?
August 18, 2025 at 1:33 pm #17328068
ziga pipan
No, I have never. changed it. Bundled products were never copied from original language. I had to add them manually and that worked. Since the update (i think) I can't even do that....
August 18, 2025 at 2:49 pm #17328305
Laura
If you use the WPML editor to translate them do you still have the issue?
August 18, 2025 at 6:34 pm #17329199
ziga pipan
everything was translated with CTE
August 19, 2025 at 7:21 am #17329839
Laura
If I provide you with a Sandbox, would you be willing to install WooCommerce Product Bundles and try to reproduce the issue?
August 19, 2025 at 8:49 am #17330409
ziga pipan
sure
August 19, 2025 at 2:01 pm #17331738
Laura
Thanks, here you go: hidden link
WPML is already installed, you just need to configure it like it is on your site.
August 19, 2025 at 2:27 pm #17331801
ziga pipan
hey.
i found that _wc_pb_aggregate_weight, _wc_pb_bundled_items_stock_sync_status, _wc_pb_sold_individually_context, _wc_pb_virtual_bundle custom fields were set to don't translate. I set them to copy now and it works. this must have automatically happen with the latest update because before that it was working ok.
anyway, is there a trick that lets me update all the procucts at once? I hate to make a minor chanhe to an original product then update translation for each language... it takes too much time.
I have some other issue here, where custom tab (youtube video) is not translated. I can copy the field ok, when I save it it looks ok, but when I referesh the page it goes missing.
here is a screencast
New threads created by Laura and linked to this one are listed below:
https://wpml.org/forums/topic/iframe-doesnt-save-in-cte/
August 19, 2025 at 2:47 pm #17331847
Laura
If you use automatic translation, just resend everything to translation and it will be fixed.
Otherwise, you can try a bulk update feature or with plugin. You first bulk update the original products, and then switch languages and bulk update again.
About the YouTube issue, since it's a different problem I'll split the ticket and we can continue there.
August 19, 2025 at 2:48 pm #17331849
ziga pipan
ok thank you
