You need to change the URL translation for WooCommerce products.
We recommend enabling the translation of the product slug by adjusting your WPML settings. Here’s how you can do it:
1. Navigate to WPMLSettingsTranslated documents options and select the “Translate” option. This setting allows the slug to be translated manually.
2. If you are working with an existing product and its translation, trigger an update to make the slug appear in the Translation Editor by:
a. Making a small change to the product description in the original language.
b. Updating the product.
c. Opening the Translation Editor for the translated product.
After these steps, the slug field should be available for manual translation in the Translation Editor.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
Last updated by olafsO 2 days, 1 hour ago.
Assisted by: Andrey.
March 12, 2026 at 9:49 am #17891552
olafsO
where to change URL translation for woo products?
March 12, 2026 at 10:03 am #17891646
olafsO
Hey. Well, basically the chat with catbot. Did everything, but still do not see where to actually change that URL :/
March 12, 2026 at 10:58 am #17891891
Andrey
WPML Supporter since 06/2013
If I understood correctly from the chat, you would like to translate the product slug.
To enable this, you need to include the slug in the translation settings. You can do this by going to WPML → Settings → Translated documents options and selecting “Translate” (this option allows the slug to be translated manually instead of being automatically generated from the title).
If you are testing this with an existing product and its translation, you will need to trigger the update so the slug appears in the Translation Editor. You can do this by following these steps:
1. Make a small change to the product description in the original language.
2. Update the product.
3. Open the Translation Editor for the translated product.
After that, the slug field should appear in the translation, allowing you to translate it manually.
March 12, 2026 at 11:06 am #17891924
olafsO
Gotca. Small change, Update, Edit. Muchos gracias!
