Last updated by Long Nguyen 1 year, 1 month ago.
Assisted by: Long Nguyen.
June 7, 2024 at 1:28 am #15713593
stevenc-14
I am trying to change my Chinese font on a site under development using the Pixel Essentials theme. I want to use the Noto Sans TC font from Google Fonts.
No specific issue or error message mentioned.
How can I change my Chinese font to Noto Sans TC using WPML?
June 7, 2024 at 3:53 am #15713681
Long Nguyen
WPML Supporter since 02/2022
Hi Steven,
Thank you for contacting WPML support, I’m happy to help you with this issue.
Do you want to use a different font for the content in Chinese language? If yes, I suggest you use the WordPress editor to have different page content and settings per language.
Refer documentation https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/
Or you can use a custom CSS code to apply the font family to the content in the Chinese language only. For example:
html[lang="zh-hant"] body p {
    font-family: Noto_Sans !important;
Note: this is a custom code and it is out of the scope of WPML.
If you are not able to accomplish this, I would recommend you contact one of our certified partners who will be more than happy to help you with this. In this link, you will find a list of our certified partners: https://wpml.org/contractors/
The topic ‘[Closed] chinese fonts choices’ is closed to new replies.
