- 12:00 – 15:00 12:00 – 15:00 12:00 – 15:00 12:00 – 15:00 12:00 – 15:00 -
Last updated by Lucas Vidal de Andrade 8 months, 1 week ago.
September 9, 2025 at 12:18 pm #17387013
larsS-15
I was trying to reconnect with Lucas Vidal de Andrade after losing connection.
The connection to Lucas Vidal de Andrade was lost, and I am unable to reconnect.
How can I reconnect with Lucas Vidal de Andrade?
What might be causing the connection to be lost?
September 9, 2025 at 1:31 pm #17387290
WPML Supporter since 11/2023
Hello there,
I wasn't able to reproduce the issue locally, after following the steps I provided to you. Perhaps because it's a different server. In this case, I kindly ask you to create a staging version of your website (an identical copy), and provide me with access.
IMPORTANT
- If you do not see the wp-admin/FTP fields, this means your post and site login details are being made PUBLIC. DO NOT post your website details if you do not see the required wp-admin/FTP fields. If you do not, ask me to enable the private box. The private box looks like this:
The topic ‘[Closed] connect me to Lucas Vidal de Andrade again. connection lost’ is closed to new replies.
