Last updated by Lauren 1 week, 2 days ago.
Assisted by: Lauren.
July 1, 2025 at 2:21 pm #17188946 | |
martinK-154 |
July 1, 2025 at 4:21 pm #17189494 | |
martinK-154 |
I tried using a different font that was not uploaded manually. When changing the font in theme settings for main language it worked but it did not work on translated domains. Then I went to the translated domain and tried saving the font there in theme setting. The font then worked on that domain but not on the default domain or any other domains anymore. Is it possible to let share you the log in credentials and you can check what the problem is? |
July 1, 2025 at 6:10 pm #17189817 | |
Lauren WPML Supporter since 10/2015
Languages: English (English ) Timezone: America/New_York (GMT-04:00) |
I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it. Our Debugging Procedures I will be checking various settings in the backend to see if the issue can be resolved. Although I won't be making changes that affect the live site, it is still good practice to backup the site before providing us access. In the event that we do need to debug the site further, I will duplicate the site and work in a separate, local development environment to avoid affecting the live site. Privacy and Security Policy We have strict policies regarding privacy and access to your information. Please see: **IMPORTANT** - Please make a backup of site files and database before providing us access. - If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box. The private box looks like this: hidden link |
July 2, 2025 at 2:03 pm #17193480 | |
martinK-154 |
Sorry for the late reply but the correct fields do not appear when answering this message. Hopefully you can enable the private box. |
July 3, 2025 at 2:56 pm #17198010 | |
The next reply is marked as private so you can safely share credentials. |
July 7, 2025 at 6:03 pm #17210881 | |
Since saving it in theme options changes it per languages, I went to the admin texts where theme option terms are typically saved. I searched for Jost as an example and found it, then added it to the translation table. Please test this for your custom fonts. Once it is added to string translation, simply copy the string so that it says Jost for all languages (or whichever your custom font is). Please let me know if this resolves the issue. |
